Guest sfde71 Posted May 22, 2008 Share Posted May 22, 2008 Hey guys, I just installed Larry's lowering blocks and got the shifter a brake adjusted, but I'm not sure how to get the rear brake light to shut off now. Any help would be appreciated. Thanks, Matt Link to comment Share on other sites More sharing options...
Guest Posted May 22, 2008 Share Posted May 22, 2008 Hey guys,I just installed Larry's lowering blocks and got the shifter a brake adjusted, but I'm not sure how to get the rear brake light to shut off now. Any help would be appreciated. Thanks, Matt If it's a 6th gen, there is a knurled plastic nut that sits on top of the plastic actuator switch. Pull up on it to get it out of the plate hole so you don't have as much drag on it when spinning it. Turn it upwards (more threads below it than on top of it) to delay the brake light actuation, turn it the other way to get quicker actuation. It's fairly simple to do, no special tools other than some nimble fingers. Lay on your back on the right side of the bike and the piece is easy to see. It's right behind the brake pedal arm. Link to comment Share on other sites More sharing options...
Guest Posted May 22, 2008 Share Posted May 22, 2008 Great, I will go check that out. Thanks Hey guys,I just installed Larry's lowering blocks and got the shifter a brake adjusted, but I'm not sure how to get the rear brake light to shut off now. Any help would be appreciated. Thanks, Matt If it's a 6th gen, there is a knurled plastic nut that sits on top of the plastic actuator switch. Pull up on it to get it out of the plate hole so you don't have as much drag on it when spinning it. Turn it upwards (more threads below it than on top of it) to delay the brake light actuation, turn it the other way to get quicker actuation. It's fairly simple to do, no special tools other than some nimble fingers. Lay on your back on the right side of the bike and the piece is easy to see. It's right behind the brake pedal arm. Link to comment Share on other sites More sharing options...
Question
Guest sfde71
Hey guys,
Thanks,
Matt
2 answers to this question
