Procedure for Fuel Injected VFR models
VTEC follows below on a reply post
To diagnose a fuel injection problem on a 5th generation vfr with the ECM self diagnosis feature,
Begin by removing the seat, locate the ?service check connector? and you will have to find a ?jumper wire? not provided.
1. With the ignition key to off and the engine stop switch on RUN
2. Short the ?Service Check Connector?
3. Turn the ignition key to on, do not start the bike though
4. If the ?FI? lights up and sta
