Twistedkeys Posted October 23, 2021 Share Posted October 23, 2021 I'm attempting to diagnose the MAP sensor on my 2010 due to a MIL code, but to begin with, there's not even a hose connected to it. I believe it's supposed to go somewhere that creates a VACUUM??? Cheers! Link to comment Share on other sites More sharing options...
Member Contributer Grum Posted October 23, 2021 Member Contributer Share Posted October 23, 2021 Sorry don't have a 1200 and the Service Manual pictures are fairly poor quality wise. Found this drawing, hope it helps. Have a very good look around the general area there must be a hose looking for a home near by! Are you sure you're actually looking at the MAP sensor? It appears to be located at the forward left side of the throttle body housing, unlike the 5th 6th and 8gen. (2) is the hose. (1) is the MAP Sensor Link to comment Share on other sites More sharing options...
Twistedkeys Posted October 23, 2021 Author Share Posted October 23, 2021 5 hours ago, Grum said: Sorry don't have a 1200 and the Service Manual pictures are fairly poor quality wise. Found this drawing, hope it helps. Have a very good look around the general area there must be a hose looking for a home near by! Are you sure you're actually looking at the MAP sensor? It appears to be located at the forward left side of the throttle body housing, unlike the 5th 6th and 8gen. (2) is the hose. (1) is the MAP Sensor Thanks mate, had that same diagram (thanks Honda), finally decided to dig around in the vacuum hose collection beneath the throttle body, lo and behold, there was a vacuum tube I had thought was a drain tube, angeled perfectly for the MAP sensor, albiet tucked away. In retrospect, it makes no sense whatsoever why a drain tube with be directly connected with the vacuum system xD. Cheers! Link to comment Share on other sites More sharing options...
