Member Contributer Ronsk Posted August 27, 2021 Member Contributer Share Posted August 27, 2021 I have a feeling the starter clutch needs rebuilding or a kit. Ah, the sound of the starter motor spinning while trying to engage the engine. In Austraila, and from what I have fond everywhere else, Honda has discontinued the 15x16 roller part # 91101-422-000 I can still buy the cap and spring but not the 15x 16 roller. Any ideas.... looking for either an alternative part or a honda part if this part was superseded. Link to comment Share on other sites More sharing options...
squirrelman Posted August 29, 2021 Share Posted August 29, 2021 it could be as simple as replacing 3 small springs at minimal cost. get it in your hands and apart to check. Link to comment Share on other sites More sharing options...
Member Contributer FromMaine Posted August 30, 2021 Member Contributer Share Posted August 30, 2021 On 8/27/2021 at 2:47 AM, Ronsk said: I have a feeling the starter clutch needs rebuilding or a kit. Ah, the sound of the starter motor spinning while trying to engage the engine. In Austraila, and from what I have fond everywhere else, Honda has discontinued the 15x16 roller part # 91101-422-000 I can still buy the cap and spring but not the 15x 16 roller. Any ideas.... looking for either an alternative part or a honda part if this part was superseded. Squirrelman is right, I have never found a roller to be out of spec. Take a micrometer to them and check. Also the housing as I did have one that was suspect. If it all looks good see if you can order the springs and caps from Honda. I have not had much luck trying to cheap out with alternative springs in the past. I did have a bit of luck stretching the springs a bit to get a bit of life out of them, but its a diminishing returns effort. Try it if lead times seem to be a bit long. Also take note of the index marks on the gears before disassembly. Link to comment Share on other sites More sharing options...
Member Contributer Ronsk Posted August 31, 2021 Author Member Contributer Share Posted August 31, 2021 Okay, Honda springs and caps it is then. Thankyou. Link to comment Share on other sites More sharing options...
