Member Contributer Mohawk Posted August 10, 2021 Member Contributer Share Posted August 10, 2021 There is a spring behind the piston to ensure it stays attached to the end of the rod. When you remove the slave you should put a clamp on it to stop the soft spring pushing the piston out. As suggested you can use a C-clamp to SLOWLY move it back in, remember you are forcing fluid back through the M/C bleed hole. If you want it to move faster, then crack the bleed nipple & after adding a hose & fluid catcher, then you can push it back with your fingers. Remember to top up the M/C with fresh fluid. When reinstalling, get everything ready, remove clamp & pop slave into place, keep pressure on it with one hand. With the other hand pop bolts into place finger tight. You can let the pressure off now 👍 Hope that helps. Link to comment Share on other sites More sharing options...
Member Contributer Grum Posted August 10, 2021 Member Contributer Share Posted August 10, 2021 16 minutes ago, Mohawk said: There is a spring behind the piston to ensure it stays attached to the end of the rod. When you remove the slave you should put a clamp on it to stop the soft spring pushing the piston out. As suggested you can use a C-clamp to SLOWLY move it back in, remember you are forcing fluid back through the M/C bleed hole. If you want it to move faster, then crack the bleed nipple & after adding a hose & fluid catcher, then you can push it back with your fingers. Remember to top up the M/C with fresh fluid. When reinstalling, get everything ready, remove clamp & pop slave into place, keep pressure on it with one hand. With the other hand pop bolts into place finger tight. You can let the pressure off now 👍 Hope that helps. +1 Excellent Mohawk, good one to remember. Tend to forget about the soft spring in the clutch slave. Keep thinking of brake slave cylinders which don't have the spring. Link to comment Share on other sites More sharing options...
