Member Contributer jefferson Posted July 29, 2021 Member Contributer Share Posted July 29, 2021 A little history is good me thinks. My rear brake has worked fine until I took the footpeg mount off and it was hanging by the line to the caliper. It was even upside down at one point. Come time to ride I found the rear brake would not build pressure, the pedal just went all the way through it's travel. I tried bleeding, but it would hardly push any fluid at all. I found an oem Honda rebuild kit in stock here in town and also got a Spiegler rear brake line. With the new kit and line you couldn't ask for better once bled. It was good for the ride to get it inspected, but the next ride it required much more pressure to get any action and the brake felt wooden, almost like the caliper was frozen on the pins. Now the pedal goes through it's travel and building very little pressure and that happened the 3rd time I rode it. Kind of stumped as to what is going on. Any help would be appreciated. Link to comment Share on other sites More sharing options...
