VicSev93 Posted July 17, 2021 Share Posted July 17, 2021 Hello all! Anyone know the voltage numbers for the Gen 5 TPS sensor? for both full throttle/no throttle? I removed mine fully, since it was cracked. Could not find it in the manual, please enlighten me if you can, thank you! Link to comment Share on other sites More sharing options...
Member Contributer Grum Posted July 17, 2021 Member Contributer Share Posted July 17, 2021 Here you go. You need to run the open and closed voltage checks, as it is very specific to the measured input reference 5v supply value. As per step 4 in calculating results. Open and closed voltage values are given on page 5-22 as a base line, but dependant on measured 5v reference voltage and calculation on page 5-23. 0.4 to 0.6v closed and 4.2 to 4 8v fully open. Refer attached pages. Link to comment Share on other sites More sharing options...
