VFR800RYDER4LIFE Posted April 13, 2021 Share Posted April 13, 2021 This part is leaking oil and I don't know what this part is called. Does anyone know the name of this part and it'd for a 98 VFR800F Link to comment Share on other sites More sharing options...
Member Contributer mello dude Posted April 13, 2021 Member Contributer Share Posted April 13, 2021 https://www.partzilla.com/catalog/honda/motorcycle/1999/vfr800fi-a-interceptor/right-crankcase-cover Link to comment Share on other sites More sharing options...
styran Posted April 13, 2021 Share Posted April 13, 2021 You probably just need a new gasket. You'll have to take off the fairings and drain the oil to fix it though. Try that and see if it fixes it. https://www.partzilla.com/product/honda/11394-MBG-000?ref=203eca91293ea854927da50c02c12c28262e9d7d If the problem is the cover itself leaking then that's about $300 on Partzilla for a new cover. You could probably buy some used one cheaper on eBay though. When you take off the cover to replace the gasket take a look at the inside of the cover and pray that there's no holes in it. Also make sure you don't over torque the bolts holding the cover as the threads strip pretty easily. Link to comment Share on other sites More sharing options...
