GaryN Posted April 3, 2021 Share Posted April 3, 2021 Just received Oxford Heated grips and looking for the best place to get switched power. On other bikes, I've used a relay for the heated grips connected to switched power and I'd like to do the same again. I can probably figure this out, but experience is so much better. So any help is appreciated. Thanks! Gary Link to comment Share on other sites More sharing options...
Member Contributer Grum Posted April 3, 2021 Member Contributer Share Posted April 3, 2021 Tail light power is probably a good one to tap into for your relay coil. Then main grip power via the relay contacts to the battery, protected by a fuse of course. Just keep away from using the main power for all your EFI stuff. Link to comment Share on other sites More sharing options...
courtuk Posted April 12, 2021 Share Posted April 12, 2021 On 4/3/2021 at 10:26 PM, Grum said: Tail light power is probably a good one to tap into for your relay coil. Then main grip power via the relay contacts to the battery, protected by a fuse of course. Just keep away from using the main power for all your EFI stuff. Sorry to hijack post, but I'm putting a relay from my rear lights, now can I run my heated grips and a USB /voltmeter thing from the same relay or would I need two? Link to comment Share on other sites More sharing options...
Member Contributer Terry Posted April 12, 2021 Member Contributer Share Posted April 12, 2021 2 hours ago, courtuk said: Sorry to hijack post, but I'm putting a relay from my rear lights, now can I run my heated grips and a USB /voltmeter thing from the same relay or would I need two? The voltmeter will take a trivial amount of power so no issue adding that to the same relay as the grips, but you will find the meter will show a lower voltage when the grips are running. As long as you bear that in mind then I saw no issue with that and had the same setup on my VFR. Interesting that the control for the Oxford Hotgrips is a timed pulse system; lower settings pulse the power off for longer, the off time is shorter for the higher temperature settings; this is very visible if you watch the voltage as it will cycle up and down with the heating cycles. Link to comment Share on other sites More sharing options...
