gman915 Posted January 31, 2021 Share Posted January 31, 2021 What is up with the Delkevic header collector gasket? mine doesn't even fit inside of the collector. I have FMF Apex Cans that the gasket doesn't fit over and the collector gasket doesn't fit into the collector. What a nightmare this install has been. I damaged the one they sent trying to get it to slide into the collector. It is too big to slide in (having to order a new one now). Besides that there is zero instructions on the collector gasket to boot from Delkevic. Knowing this now, I should have just kept the headers stock with welded joints that don't leak. The Yoshi exhausts on my Gixxer racebikes were of a much higher quality fit and finish. What is your experience with this install on your Gen 6 bikes? Did I just get the wrong collector gasket? 2007 RWB VFR800 (Gen 6) Link to comment Share on other sites More sharing options...
Member Contributer boOZZIE Posted January 31, 2021 Member Contributer Share Posted January 31, 2021 Are you sure u need the gasket at all? Some cans just need to be clamped to the headers Other than that, I'd follow Cogs suggestion 😉 Link to comment Share on other sites More sharing options...
Member Contributer Cogswell Posted January 31, 2021 Member Contributer Share Posted January 31, 2021 Send 'em back if you can and try to get in on the VFRD header build. Link to comment Share on other sites More sharing options...
Member Contributer DannoXYZ Posted January 31, 2021 Member Contributer Share Posted January 31, 2021 yeah send it back, you got wrong parts. Nothing ever needs to be forced (nor should you force it). Everything should drop into place when fitted by hand. Link to comment Share on other sites More sharing options...
