Biddy56 Posted December 19, 2020 Share Posted December 19, 2020 I own a 1998 5th gen VFR800f which I have had for nearly a year. Absolutely love the bike but I have an intermittent fault with it and thought maybe somebody on this forum may of had the same problem of have heard of it. My rear brake intermittently sticks on after using the rear brake pedal. Its ok when I use the front brake lever and the linked brake activates the rear caliper piston but if I use the rear brake pedal after a few presses it binds. It seems as if the rear brake is retaining pressure as the pedal is solid with no free play. The rear brake cylinder piston may be sticking. today it started to bind and the pedal was solid. I removed the pedal clevis pin, the pedal is free but the brake was still binding. I pushed and pulled the brake cylinder push rod and the wheel eventually freed. Has anyone had this problem? Link to comment Share on other sites More sharing options...
Member Contributer Grum Posted December 19, 2020 Member Contributer Share Posted December 19, 2020 Hi Biddy56. Check out this link. You might have the same issue. Link to comment Share on other sites More sharing options...
Biddy56 Posted December 24, 2020 Author Share Posted December 24, 2020 Thanks Grum, Very informative. I will have to look deeper into the problem and check out where I could pick up a secondary master cylinder. Link to comment Share on other sites More sharing options...
