Fitting a stainless full exhaust and vfr1200 shock to 2000 vfr
Duck
So do you need to make up an adapter for the shock like you do with a cbr 929 one, or is it the same length as a standard 5th gen shock?
How doesย  the spring rate compare to standard?
Keep us updated on progress and results!
I don't recall seeing a post with a 7th gen to 5th shock swap. You may the innovator on it.ย
ย
What brand headers are those?ย  They don't appear to be the VFRD headers that were done last year.ย
ย
ย
I have taken inspiration from this post ..
ย
ย
On 11/22/2020 at 11:51 PM, Duck said:
Hey, currently got a stainless full exhaust and vfr1200 shock which will be fitted to my 5th gen vfr800.ย
Making slow progress removing origianl oem exhaust.ย ๐Ÿค”
So how did you go with the install?ย  Re the S/S headers, did you have any issues?
Work took over. I still need to take off the OEM headers. However i need to release the mounting on the cat.
ย
Its an ongoing project. But will keep the forum updated.
  • 4 weeks later...
Trying to get the oem exhaust off. Struggling getting at the bolt/nut connecting the catalytic convertor to the frame
No adapter needed , just a shim to give the loat mm's.. im trying a 6mm but others have used 4mm
  • 4 months later...
On 5/4/2021 at 10:25 PM, Magneto said:
Duck - Duck- Go!ย ๐Ÿ˜€๐Ÿ˜€ How was the test ride?
The ride is vastly improved. Bikes lighter and feels even more aturdy (if even possible) bike sits a little lower and is better with the new additions
I have a spare OEM 1200 shock if anyone's interested?ย ๐Ÿ˜‰ย $$$ ๐Ÿ˜†
