fuel injector cleaning
bog
Looking for a few names of companies that do vfr injector cleaning, im in upper michigan.  i wonder if i should just buy new ones as my bike is a 2003, with 5500 miles, they could just be corroded by now, i have a low rpm miss and stumble, i have synched the throttle valves, but it definetly acts as if its lean mixture at that point, i am used to carbureated bikes, i had a 1987 vfr brand new, it was much more user friendly than these fuel injected bikes, any info would be appreciated...bog
Here in the NW, you can get injectors cleaned and tested for about 30 ea.  You can get all 4 cleaned for about the price of one new.
RC Fuel Injection in LA (Torrance)
https://www.rcfuelinjection.com/Store/c/fuel-injector-cleaning
In the last two years I've used them for my '99 VFR and '97 Volvo 855 T5.
Others on VFRD have used them.
RC will give you a before and after print out.
Stuff them in a USPS small flat rate box for $7.95
Their turn around time is 1 day.
