86 VFR750F starting problem
chill
Hi all. My 86 VFR sat in my garage for 25 years. Last year I rebuilt the carbs. At first the bike would rev way up when started so I started tracking vacuum leaks. Got it running rough but it was late Oct. so I put it away for the winter. Tried to start it this summer. It was very hard to start and when it did it ran for a minute or so then stalled. Now when it starts it runs for 2 seconds then dies. Will start right up again and then dies right away. Bike has less than 9k miles. Fuel pump squirts when I take off the fuel line but I have not tried to measure the volume it pumps. Any help with areas to check much appreciated.
You can bypass the fuel pump (make sure the tank is at least half full fresh fuel).
Fit a new fuel filter.
Use jump leads to a car battery.
Check air filter housing for nests
Check if all vacuum ports are capped
Download the workshop manual (download section here on vfrd)
stood idle for 5 years:
dija drain the gas from float bowls last time u stored it ??  if not, carbs may be plugged up. use fresh fuel, and flush the tank out, checking for debris and rust.
as dutchy suggests, jump from a car battery to eliminate the possibility of weak sparks. check charging system output as soon as u get it running.
Thanks for the ideas Dutchy - I put a new fuel pump on last year and when it wouldn't run this year swapped the old pump back in, but will try running staight from the tank. The battery was new last year and fully charged before trying to start the bike. I did pull one plug to verify I has spark and it seemed strong, but again can't hurt to try jumping it. Airbox is clean. Not sure which vacuum lines should be capped and can't remember seeing any when I rebuilt the carbs last year. The carbs do vent to atmosphere through short rubber hoses. Bought a hard copy of the service manual off Ebay last year - better picture quality than the download. I'm leaning towards it being a fuel problem (or vacuum leak) just because the spark seemd so strong when I checked it, and I'm not sure I got all of the leaks last year after reinstalling the carbs - ran out of gooos weather. Taking a 4 day weekend, so I hope to do some more troubleshooting. I will keep you posted on progress.
Squirrelman - I did run the carbs dry and pulled the tank and emptied through the opening for the fuel guage before putting it away for the winter. Learned my lesson the hard way, taking the carbs on and off twice last year. I will follow you and Dutchy's suggestion to jump it from my car battery. I did buy new carb boots and another carb rebuild kit that has replacement jets (the one I used last year didn't). Saving that for the nuclear option although I now have LOTS of experience taking the carbs off and on. I did read on another thread several people saying don't take the carbs off the intake plenum.....but I did. I think I got a decent bench synch, but it was the first time I have done a multiple carb setup. No fuel leaks. Apologies for not responding to you and Dutchy sooner - I also have a MGB project going and have been working on that for the last couple of weekends.
Ah! I checked the fiche. Where the later VFR have these
and now capped
the 86 have a small bolt (#22) with washer (#16)
If one or more are missing, the engine will suck "false air" in ......  (as we say in Dutch 🙂 )
OK, i remember laying on my back under my '57 MGA to bash the Lucas electric fuel pump into working again.
  • 4 weeks later...
This was in Practical Sportsbike at the end of an interview with a RC30 specialist, his favourite tools
