russellbig42 Posted August 10, 2020 Share Posted August 10, 2020 Hi my left headlight is not working the right one is working fine, the green wire mod had been done, also ive got 12v at the plug and the bulb is good as ive checked it on the other side Link to comment Share on other sites More sharing options...
Member Contributer Grum Posted August 10, 2020 Member Contributer Share Posted August 10, 2020 Have you made sure the Green wire from the globe plug is properly Grounded, that means continuity back to the Battery Negative terminal? If your Ground is good and you have a solid 12v measured at the globe socket then the light should work UNLESS you have some form of corrosion or bad socket joint to the globe. Is your bike configured like the drawing attached? Four separate globes in total? Link to comment Share on other sites More sharing options...
russellbig42 Posted August 15, 2020 Author Share Posted August 15, 2020 hi the green wire mod had been done but ive ran a second ground wire off the light plug and that works i got light from that side Link to comment Share on other sites More sharing options...
Member Contributer Grum Posted August 15, 2020 Member Contributer Share Posted August 15, 2020 26 minutes ago, russellbig42 said: hi the green wire mod had been done but ive ran a second ground wire off the light plug and that works i got light from that side Glad you have it sorted. A faulty ground for the light by what you're saying. Link to comment Share on other sites More sharing options...
