Diiikco Posted July 3, 2020 Share Posted July 3, 2020 Hello, Does anyone have the torque settings for the VFR800-6? Preferably in .Pdf. If not I specifically need, the front break nut to filling reservoir at the handles bars. Same for the clutch side. The nuts just below the filling reservoirs. I'm installing heli bars and I need to angle the cables slightly forward so they require loosening. But I'm a stickler for doing things right so want to tighten them back up correctly. Thanks, Rory Link to comment Share on other sites More sharing options...
Member Contributer Skids Posted July 3, 2020 Member Contributer Share Posted July 3, 2020 There should be a workshop manual available in the Downloads section. That will have every torque figure you should need. Link to comment Share on other sites More sharing options...
Diiikco Posted July 3, 2020 Author Share Posted July 3, 2020 Thanks 7 hours ago, Skids said: There should be a workshop manual available in the Downloads section. That will have every torque figure you should need. Thanks. I found it. Didn't realise that section existed. It's below for anyone that needs it. https://www.vfrdiscussion.com/index.php?/files/ Link to comment Share on other sites More sharing options...
