Rear shock linkage arm seals
Earl
Hi all, I've got the swingarm, shock and linkage off, first of all to check the bearings and secondly to fit an R1 shock.
The bearings are OK but the seals on the linkage arm need replacing. Can anyone recommend a supplier. I'm in Sydney.
Thanks!
I think you're speaking of the 17x24x5 oil seals, pn. 91262-KV3-831.  They are available from Honda, but I would probably go to a specialist bearing supplier and simply provide the dimensions, e.g., https://simplybearings.co.uk/shop/p24278/17x24x5mm-Nitrile-Rubber-Rotary-Shaft-Oil-Seal-R21-/-SC/product_info.html  They're not exactly cheap, but it appears they are available from many sources.
Ciao,
JZH
  • 3 weeks later...
