8200rpm Posted March 16, 2020 Share Posted March 16, 2020 So the little plastic nub on inside of the switch pod housing that fits into the clip-on recess hole broke off. So the entire housing free spins on the clip-on. It's especially annoying when I'm trying to open and close the choke (fast idle lever). Is there a hack or fix for this? I tried torquing down on the screws but that only clamps the two plastic parts together. It doesn't provide any additional clamping force onto the clip-on. Link to comment Share on other sites More sharing options...
Member Contributer ChrisBezz Posted March 16, 2020 Member Contributer Share Posted March 16, 2020 Hi, 8200 - just wondering, how did it happen? Chris B. Link to comment Share on other sites More sharing options...
Member Contributer carlgustav Posted March 16, 2020 Member Contributer Share Posted March 16, 2020 If you just need a simple hack for the near term (and this is truly a hack), then get some of the anti-slip tape (Lowes, Skid Guard) and wrap just enough under the housing to clamp on. It's been working for me on my track bike for many seasons. It's not a proper fix and doesn't look great up close, but works ... ACE Link to comment Share on other sites More sharing options...
Member Contributer JZH Posted March 16, 2020 Member Contributer Share Posted March 16, 2020 Any second-hand Honda switch pod from eBay that looks like yours should swap housings with yours. Of course, it could also snap off... Ciao, JZH Link to comment Share on other sites More sharing options...
Member Contributer Terry Posted March 16, 2020 Member Contributer Share Posted March 16, 2020 You could also do what some bodger PO did to my new purchase; drill through the switch casing and into the bar, and insert a self-tapping screw. This was done from below where it's not obvious, and doesn't affect functionality, but its not exactly elegant. Link to comment Share on other sites More sharing options...
Member Contributer MaxSwell Posted March 17, 2020 Member Contributer Share Posted March 17, 2020 Just brain storming here. Can you replace the broken nub with anything and some plastic glue? Plasti-Fix works on ABS. Replace it with a metal pin with threads into the housing? Link to comment Share on other sites More sharing options...
8200rpm Posted March 17, 2020 Author Share Posted March 17, 2020 17 hours ago, ChrisBezz said: Hi, 8200 - just wondering, how did it happen? Chris B. It might have weakened over time from the resistance of the choke lever. More likely, the nub wasn’t lined up to the recess when I installed it. So, it could have snapped off when I tightened the screws. Link to comment Share on other sites More sharing options...
8200rpm Posted March 17, 2020 Author Share Posted March 17, 2020 22 minutes ago, MaxSwell said: Replace it with a metal pin with threads into the housing? This might be the most elegant fix. I gotta find a small Allen set screw that’s about the same diameter as the hole in the clip on. Drill a little hole in the plastic housing and thread it through. Thanks for the idea! Link to comment Share on other sites More sharing options...
Member Contributer MaxSwell Posted March 17, 2020 Member Contributer Share Posted March 17, 2020 6 minutes ago, 8200rpm said: This might be the most elegant fix. I gotta find a small Allen set screw that’s about the same diameter as the hole in the clip on. Drill a little hole in the plastic housing and thread it through. Thanks for the idea! Perfect! Link to comment Share on other sites More sharing options...
JoelF Posted March 17, 2020 Share Posted March 17, 2020 The rude solution is a few wraps of electrical tape on the bar. It's soft enough to get mashed into the crevices and lock the pod to the bar pretty well. Link to comment Share on other sites More sharing options...
Member Contributer ChrisBezz Posted March 18, 2020 Member Contributer Share Posted March 18, 2020 Ha! maxSwell beat me to it! I thought of suggesting a piece of metal rod with a thread cut into it. Same end result. i hope you get it sorted? Chris B. Link to comment Share on other sites More sharing options...
