Boneyard Posted December 13, 2019 Share Posted December 13, 2019 Slipping clutch? At the bottom the clutch fluid reservoir there is a small metal tab. This is a spatter guard. Underneath this in a small depression is a tiny hole which allows the fluid to re-enter the reservoir. When this becomes clogged the clutch will slip. Use a small pin to unclog this. Away you go! Always check this first. Link to comment Share on other sites More sharing options...
