Akro exhaust question
HareBrain
The bike I just bought came with the Akro exhaust and the baffle already removed. When I came to try to fit it, the baffle was really tight. I couldn't push it all the way in by hand, and even then I had to use pliers to pull it out again. Is that normal? I didn't want to try with a mallet etc till I found out more.
Thanks in advance!
ETA: just occurred to me that maybe it would be easier when it's been running and the exhaust is hot and has expanded a bit. I'll try that next dry day
It’s a tight fit, so that’s normal, I just push mine in for the MOT and remove it after
Surely the inner walls of the tube that holds the spud will expand to make the hole smaller??? :goofy:
Try cleaning the inside where it slides in. Otherwise, consider leaving it out....LOUD EXHAUSTS SAVE LIVES!
Mine has been out for 3 years, not failed an MoT and sounds very nice!
Thanks guys. It literally can't be pushed in at the moment, but I'll try cleaning (if warming it up doesn't work). I might end up leaving it out, but I'd like to see how it sounds with it in. I live in a narrow terraced street that's a bit of an echo-box.
6 hours ago, HareBrain said:
.....but I'd like to see how it sounds with it in.
Too quiet 😆
7 hours ago, VFR4Me said:
What's an MoT?
Stands for Ministry of Transport (Test), an olde English term for a UK government organisation which no longer exists requiring an annual test of roadworthiness that all vehicles must pass on their 3rd and subsequent birthdays.
9 hours ago, VFR4Me said:
What's an MoT?
That reminds me ...
Mine came with a new MOT with baffle out, so it can't be necessary. But do you not bother using the bolt? That looks like a real PITA to do up.
I bet loads of younger drivers say MOT without having a clue what it stands for. It's a bit like the save icon being a 3.5" floppy.
Nope.
Experimenting with swapping the baffle in and out (as far as I can get it) and the engine running, it muffles the bass, but this is only noticeable when idling. Doesn't sound much different at all when revved. I can't imagine I'll be doing many 4am starts on it, so it should be OK left out.
