6th Gen Drive Chain/Gear (Oil Pump)
AcedIt
Hey all. I have the right side engine cover off while inspecting my timing chain(s) and started to look at other things as well. In my video below you can see the drive chain gear has movement inward and outward and the chain has a lot of slack. I've read slack in the chain is normal, maybe to 10mm of play. However, does it look a bit much? I'm not certain about that gear movement though either. Almost 70K on my 6th gen. Comments?
