Member Contributer jdmtrinidad Posted October 16, 2019 Member Contributer Share Posted October 16, 2019 Did a little work this week off. I have been acquiring all the rubber for brakes, coolant, (including t-stat, water pump, fan switch) and header with staintune exhaust. Here are some pics through the process. I'm not the best at documenting because once I get on a roll, I'm super focused on just work.All coolant lines replaced. Used a piece of wood to pry off the throttle bodies to get to the thermostat and housings.sorting through all the brake parts to rebuild entire systemthis is how I sorted through all the bitsclutch master before and afterrear master hose inlet tubeanybody else get as excited as me rebuilding brakes?2nd master cylinder was in rough shape. Link to comment Share on other sites More sharing options...
Member Contributer jdmtrinidad Posted October 16, 2019 Author Member Contributer Share Posted October 16, 2019 front calipers after kerosene clean and sonic cleaner bathafter header installed loosely. Not yet happy with exact fitment. I will be adjusting things on my next time off in 2 weeks.OPoh yeah, spiegler brake lines. I know, I know, white with blue fittings sounds boy racer, but I think it works.Well, that's about all I had time for. Kind is sucks because the weather here in Austin was ideal for a ride, but I need things perfect before I take her back out. I will finish next time and next post. Link to comment Share on other sites More sharing options...
Member Contributer KevCarver Posted October 16, 2019 Member Contributer Share Posted October 16, 2019 Nice work! I also like taking brake calipers apart and cleaning. Link to comment Share on other sites More sharing options...
Member Contributer interceptor69 Posted October 16, 2019 Member Contributer Share Posted October 16, 2019 That's some nice work!Sent from my SM-G955U using Tapatalk Link to comment Share on other sites More sharing options...
