Member Contributer Lannyl81 Posted October 15, 2019 Member Contributer Share Posted October 15, 2019 This is on my '97...has carbs....remember those?....anyways I have had a Delkvic slip-on with the plug or dB killer out. Have always wondered if I should install stage 2 jets or not. Still using the stock style air filter and have removed the PAIR stuff. I recently changed the plugs; old ones looked fine, not burnt or anything. This Winter I will be checking the valves and probably pulling the carbs out...so it would be a good time to install the stage 2 jets.....if needed. The only characteristic I have noticed is engine is a bit "cold-natured" even here in southern Arizona Stock sizes are: Slow jet #40, Main jet front #128, rear #125. The kit I have has: Slow jet #42, Main jets #130. I was thinking of replacing the slow jets and then use the #130 in the front and #128 in the rear. What you guys think??. Link to comment Share on other sites More sharing options...
