Member Contributer Fritzer Posted September 14, 2019 Member Contributer Share Posted September 14, 2019 My left front fork sprung a leak about a month ago. I caught it pretty early so it didn't make a big mess. While I had the bike apart, figured that rebuilding both would be the wise course to take. I am very luck to have friend that was a dealer mechanic for many years and his knowledge is amazing. I took my forks out and he did the rebuild on them. One of the things he pointed out to me was the micro pits in the fork tube from encounters from rocks. The tube guard blocked most of the impacts, but not all. One of the things Jim recommended was to install some fork boots. His arguments were very compelling, so I ordered up some Polisport fork bellows to fit a 40mm fork tube to a 60mm housing diameter. They were only $20 and good quality rubber material. However, they were too long so I just cut them to length. Zip tied to the fork tube at the top, and covered the entire top of the lower housing, including the existing fork tube guard. Zip ties bellows to the lower housing (with the vent holes rear facing). This effort does a couple of things. Stops contact between seals & dried bug remains Stops rock pitting Dramatic reduction in dirt making it past the seals into the fork oil. Way less wear on bushings. There is a caveat here however. The bellows are wider than the fork tubes and enter into the airflow pathway to the radiators a little bit. I have noticed that moving thru un-turbulated air, my cruise temperature is about 4 f degrees higher. Turbulated air makes a +7 degree over normal condition. I live in Portland Oregon area, so it is usually not super hot here. Mostly dealing with slow or stopped traffic around town so when it gets to fan on temp, there is no difference in cooling ability. So if you are needing to rebuild front forks in the future, this might be something of interest. Link to comment Share on other sites More sharing options...
squirrelman Posted September 14, 2019 Share Posted September 14, 2019 too ugly for my bikes..................😮 Link to comment Share on other sites More sharing options...
