Sign in to follow this
CoyoteChris
Three types of throttle locks
OK, bought a Kaoko throttle lock for 2015 VFR 800 F with Honda heated grips (HND 29) not to be confused with the HND 31 for non- heated grips. On sale for $128. Its coming.   Normally I use the NEP type throttle lock  but I dont know if I can get the rubber lip of the grip  outboard of the rim on the plastic throttle tube on a heated grip for clearance.  Other than that, I could machine the switch housing face to make it fit.  I have never tried the lever but have one coming for the experience, although the way the rubber is on the heated grip, there isnt much room for it.
Share this post
I am so glad I saw this post as I just realized I have ordered the wrong kaoko throttle lock. I have heated grips and ordered the one for non heated grips but was able to cancel the order in time. So thank you for that!
Share this post
For others checking this thread, here is the on that works best for me. Simple, inexpensive, and easy to apply or release. Of course, I'd prefer a true cruise control.
Edited by Lorne
hit submit to soon
Share this post
It was a near thing for me also...they should have put in the description of one that it wasnt for the other, or one was for F and one was for FD. Oh well.
Share this post
I have one like this on order but with a bigger thumb activator. The problem with using this on an FD is the taper of the rubber off the rubber flange. It is not abrupt but about 45 degrees on the heated grips. I have small hands and there is little room as it is to put my hand on the grip. But I wanted to try it.  The biggest problem with this mechanism is the fact that its a friction device but only in one direction. If you want more throttle, you must open the throttle AND reset the lever, unlike the Kaoko or NEP. I will try the Kaoko and if that is a pain I will find a way to put on an NEP. I have used the NEP since 1985 and have no complaints.
Share this post
I never liked the Go Cruise, went for a Scottoiler Crampbuster instead.
YMMV
Share this post
Well that's a little confusing. Just checked mine which I fitted a few years ago it's the HND31, and I most certainly have heated grips. Installed without issue and works a treat!
Think it's more about the internal dia of the tube rather than heated grips or not.
Share this post
