skant153 Posted July 24, 2019 Share Posted July 24, 2019 On the way to work this morning I noticed my indicators stopped working. I know the left worked on the first turn but after that, nothing. The running lights are on and the switch turns them off. Any ideas where to start? Link to comment Share on other sites More sharing options...
Member Contributer Grum Posted July 24, 2019 Member Contributer Share Posted July 24, 2019 If you're not getting a blink on either side then it might be the Turn Relay. First check Fuse C hasn't blown, check that you have 12v at the Turn Relay Black/Brown wire and the Green Ground wire at the Turn Relay is properly grounded. Assume all your globes are good and of the correct wattage? Also poor blinker switch contacts will can cause issues. Link to comment Share on other sites More sharing options...
Member Contributer KevCarver Posted July 25, 2019 Member Contributer Share Posted July 25, 2019 Easiest place to start is to spray some electrical contact cleaner into the switch and work it back and forth. Might want to actually take it apart. Signal relay is under the front upper cowl, on the cowl stay. It's a PITA to get to. There's 2 side by side on the right (throttle side), and I am thinking it's the outer one. Link to comment Share on other sites More sharing options...
skant153 Posted July 25, 2019 Author Share Posted July 25, 2019 i'll start taking it apart this afternoon. i'll have to get some cleaner anyways. my cbr has a single pin corroded on the connector for my light control. Link to comment Share on other sites More sharing options...
StardusterToo Posted July 25, 2019 Share Posted July 25, 2019 Just did mine - the indicator stopped and the high beams were low only. This worked for me. It's pretty close to the vfr, just keep all the bits in order - there's a lot of pieces!. Cheers. Link to comment Share on other sites More sharing options...
