Sign in to follow this
Whiplash316
DIY tail tidy/fender eliminator
Out of desperation to get rid of the huge mud flap that came on my 2014 VFR800, I made my own tail tidy out of parts that came off of the stock rear fender. Hopefully the pictures explain everything well enough that others can follow along if they are looking to do something similar. I didn’t think of making a tutorial until I was already almost finished with it. I cut the plastic mud flap part where it bolts onto the tail in order to use it to fill the space and to strengthen the attachment point. Sanded and drilled a couple of holes in it. Then took two brackets off of it. One of them I drilled two holes into and the other I cut tabs off of and grinded and sanded the lower portion off of. Both brackets were then stripped of the factory paint and then painted in a semi gloss spray paint. Stainless steel bolts were used along with some factory bolts to attach it. It sits perfectly under the factory license plate light and is much higher than stock. It almost looks factory and I’ve only got the cost of a can of spray paint into it plus my time. I hadn’t seen anyone do this yet, so figured I’d share since there aren’t many options.
Share this post
Oooofff, what's with the white on black text? I have no idea what you wrote because it's too painful to look at!
Share this post
Neat but illegal over here due to the lack of a reflector. Odd isn't it? You have to have orange ones on the sides and forks, we don't but still have to have a red rear one (despite now having enormous reflective yellow rear air-brakes masquerading as registration plates!).
Share this post
Don’t know what happened with the text. I think something on the forum went wrong.
Share this post
Usually I’m very anti diy tail tidy, but this one came out nice. Good job!
Share this post
Retyped for your sensitive eyes-
Out of desperation to get rid of the huge mud flap that came on my 2014 VFR800, I made my own tail tidy out of parts that came off of the stock rear fender. Hopefully the pictures explain everything well enough that others can follow along if they are looking to do something similar. I didn’t think of making a tutorial until I was already almost finished with it. I cut the plastic mud flap part where it bolts onto the tail in order to use it to fill the space and to strengthen the attachment point. Sanded and drilled a couple of holes in it. Then took two brackets off of it. One of them I drilled two holes into and the other I cut tabs off of and grinded and sanded the lower portion off of. Both brackets were then stripped of the factory paint and then painted in a semi gloss spray paint. Stainless steel bolts were used along with some factory bolts to attach i t. It sits perfectly under the factory license plate light and is much higher than stock. It almost looks factory and I’ve only got the cost of a can of spray paint into it plus my time. I hadn’t seen anyone do this yet, so f igured I’d share since there aren’t many options.
Share this post
Thanks!
Share this post
My astigmatism thanks you!
Edit: Nice work.
Share this post
Did you copy and paste from VFRWorld? 😉
Share this post
Ahh, is that what it was? I did. Didn’t seem to be much traffic over there so I tried here. Seems like this is a more popular forum.
Share this post
Forums in general seem to get a lot less traffic these days. Everyone just uses Facebook for everything. Personally, I find Facebook much too invasive for my tastes.
Share this post
Agree with that, no facebook for me either. 😎
Share this post
