Member Contributer whiteknuckles Posted May 6, 2019 Member Contributer Share Posted May 6, 2019 After my bike is well warmed up, like 200 fahrenhiet, the idle speed drops and the engine dies. I turned up the idle speed from 1100 to about 2000 rpm, but the problem continues. Starts right back up. If a massage the throttle, I can hear a clicking under the tank as the revs go up/down. Any ideas? Link to comment Share on other sites More sharing options...
Member Contributer Grum Posted May 6, 2019 Member Contributer Share Posted May 6, 2019 Wonder if you're hearing the Air Intake Flapper Solenoid activating, are all your Vaccum hoses good with no leaks? Could it be that the air intake flapper Vaccum hose to the diaphragm is not on? Link to comment Share on other sites More sharing options...
Member Contributer whiteknuckles Posted May 7, 2019 Author Member Contributer Share Posted May 7, 2019 18 hours ago, Grum said: Wonder if you're hearing the Air Intake Flapper Solenoid activating, are all your Vaccum hoses good with no leaks? Could it be that the air intake flapper Vaccum hose to the diaphragm is not on? The flapper is disconnected and the vacuum line plugged. Will be opening up the airbox in a day or two to check out the vacuum lines. Was just hoping for a quick fix had someone else had this problem before. Trying to do a search on this site is difficult. Link to comment Share on other sites More sharing options...
