Sign in to follow this
LoneInterceptor61
Suspension upgrade/Lowering link
I was wondering if there are any ohlins suspension or any good brand that makes suspension upgrades for the 2014 VFR. And also in the market for lowering kit for the VFR. I tried looking but only seen Ebay parts and kinda iffy about Ebay parts.
Share this post
I've god short legs (27in inseam) myself and putting the seat in the lower position works for me, not flat footed but hanelable. You have the seat in the lower position?
Share this post
No I didn't even know I could adjust the seat. I do believe the last owner stiffened the load by alot. I can hardly press down on the rear seat cowl and it won't decompress the rear. I have to really push down on it with two hands to get it to decompress.
Share this post
Have you tried adjusting the suspension or do not have adjustment?
Theres a couple of good threads on setting the suspension up
Share this post
Start here then sound like others have said proper suspension setup would help.
Share this post
Yup that is your preload adjuster. C spanner in and turn the higher the step the more preload.
Share this post
So just loosen that pre-load, and it will help soften things up?
Share this post
Yep turn it to the left.
Share this post
7 hours ago, LoneInterceptor61 said:
I cant tell if this is adjustable or not but this is my stock suspension that is sitting on the bike.
It looks to me that it’s on the second lowest setting.
Giving it one more click will soften it, not by very much but worth a try.
Better still check and adjust your sag, that will tell you if you need a softer spring.
Share this post
Well I took apart the seat and mounting brackets.... didn't know factory torqued them with 1,000,000lbs of torque, I heard a pop as I loosened them up and thought I snapped something lmao. I put the seat brackets as low as I could get them and what a difference. I feel more centered and not like I'm going to fall over like I did before.
Being 6'3" and riding, it's almost a gift and a curse hahaha. I still wouldn't mind lowering it half an inch but for now Ima ride and get used to the new adjustments.
Share this post
You can customise your seat height by having the front on low and the back of the seat on high, or vice versa
Share this post
Excellent glad I asked the obvious question and Its working for you. On my 6th gen the front forks were dropped about 1/2 inch to make the steering quicker. Thinking of trying this on my 8th though I don't need the extra bit of lowering I'll take it 🙂 The 8th gen stears quicker than the 6th a bit quicker would be nice.
Share this post
Thank you, it worked out well for me lol.  I have to look into adjusting the front forks. I don't know if I can do it with the 8th gen 800FE model. I know you can do it with the 8th gen 800 Deluxe that come with adjustable nuts right there on top
Share this post
I'll have to see how this goes and go from there but right now it's pretty comfortable for me.
Share this post
