Member Contributer george6x Posted March 22, 2019 Member Contributer Share Posted March 22, 2019 Hi does the 4th gen vfr have a fuse just for the rear lights ?? my brake lights work but no lights the headlights work not sure what this is can anyone help ? would love a wiring diagram pdf if anyone has this please. Link to comment Share on other sites More sharing options...
Member Contributer Grum Posted March 22, 2019 Member Contributer Share Posted March 22, 2019 Check fuse B 10amp. Position.Tail.Licence light.Illum. And, you might have two blown globes or the incorrect type fitted! Link to comment Share on other sites More sharing options...
squirrelman Posted March 22, 2019 Share Posted March 22, 2019 of course you replaced the bulbs when they didn't light up ? power for tail lights comes from a brown wire on the ignition switch, so you could try pulling the bottom (electrical) part of the ignition switch to inspect/clean the contacts. Link to comment Share on other sites More sharing options...
Member Contributer auggius Posted March 22, 2019 Member Contributer Share Posted March 22, 2019 I had a similar problem. If replacing bulbs or fuses don't help, it could be a broken wire within the wiring harness in the tail section. I had to open it up, find the broken wire and solder in a new piece. Good luck. Link to comment Share on other sites More sharing options...
