Member Contributer Stray Posted March 12, 2019 Member Contributer Share Posted March 12, 2019 Hello All, Anyone know what the top fork/clamp/clipon diameter is on a 7th gen VFR? Hoping they are 50mm so the clipons will fit my 5th gen fork conversion. That’ll also add 40hp, of course! All help greatfully received. Stray Link to comment Share on other sites More sharing options...
Member Contributer VFROZ Posted March 13, 2019 Member Contributer Share Posted March 13, 2019 Yep, they are 50mm. Im using the VFR1200 triples on my 5G conversion with SP1 forks. I've shimmed the bottom clamp as the SP1 forks are 53mm and 1200 are 54mm. Link to comment Share on other sites More sharing options...
Member Contributer Stray Posted March 13, 2019 Author Member Contributer Share Posted March 13, 2019 2 hours ago, VFROZ said: Yep, they are 50mm. Im using the VFR1200 triples on my 5G conversion with SP1 forks. I've shimmed the bottom clamp as the SP1 forks are 53mm and 1200 are 54mm. You’re a LEGEND, mate - thanks! Link to comment Share on other sites More sharing options...
Member Contributer KevCarver Posted March 14, 2019 Member Contributer Share Posted March 14, 2019 I have 1200 clipons mounted to SP1 forks on my 5th Gen😎 Gull Wing triples top and bottom. The 1200 clipons are taller than the 5th were, but the gull wing upper lowers them slightly below where the were. Link to comment Share on other sites More sharing options...
