UpArrrow Posted February 8, 2019 Share Posted February 8, 2019 I'd like to bring the rear down an inch or so. How can this be done? As an aside, it's going in for the recall shaft replacement within a week or two. Link to comment Share on other sites More sharing options...
srdjan Posted February 8, 2019 Share Posted February 8, 2019 What's a purpose of lowering?Rear shock could be solution, maybe..Sent from my EVA-L09 using Tapatalk Link to comment Share on other sites More sharing options...
Darrenk Posted February 9, 2019 Share Posted February 9, 2019 https://soupysperformance.com/honda/vfr1200/vfr1200-single-style-threaded-lowering-link.html I can’t tell you if it works or not... Link to comment Share on other sites More sharing options...
UpArrrow Posted February 9, 2019 Author Share Posted February 9, 2019 On 2/8/2019 at 4:11 AM, srdjan said: What's a purpose of lowering? Rear shock could be solution, maybe.. Sent from my EVA-L09 using Tapatalk Reach to the ground. I can't back it even on level concrete Link to comment Share on other sites More sharing options...
UpArrrow Posted February 9, 2019 Author Share Posted February 9, 2019 19 hours ago, Darrenk said: https://soupysperformance.com/honda/vfr1200/vfr1200-single-style-threaded-lowering-link.html I can’t tell you if it works or not... Thanks. I'll look into this one. They have used pics for the 1200x but list that bike separately. $255 for link & stand may be a palatable solution. Link to comment Share on other sites More sharing options...
squirrelman Posted February 10, 2019 Share Posted February 10, 2019 maybe you bought a bike that's too big for you ?? Link to comment Share on other sites More sharing options...
UpArrrow Posted February 10, 2019 Author Share Posted February 10, 2019 1 hour ago, squirrelman said: maybe you bought a bike that's too big for you ?? Hell yes I did. Always do. Any other kind observations? Link to comment Share on other sites More sharing options...
LookingHard Posted February 10, 2019 Share Posted February 10, 2019 UpArrow, On the off chance that you are not aware of it, if you install lowering links, it might be harder to use the centerstand, depending on the amount of lowering of course. LookingHard Link to comment Share on other sites More sharing options...
UpArrrow Posted February 10, 2019 Author Share Posted February 10, 2019 2 hours ago, LookingHard said: UpArrow, On the off chance that you are not aware of it, if you install lowering links, it might be harder to use the centerstand, depending on the amount of lowering of course. LookingHard Yeah. Not looking to drop it more than about 1". Center stand would be tougher but doable. Link to comment Share on other sites More sharing options...
srdjan Posted February 10, 2019 Share Posted February 10, 2019 Consider OEM Lower narrow seatSent from my EVA-L09 using Tapatalk Link to comment Share on other sites More sharing options...
UpArrrow Posted February 10, 2019 Author Share Posted February 10, 2019 19 minutes ago, srdjan said: Consider OEM Lower narrow seat Sent from my EVA-L09 using Tapatalk Wish I could try one. I'm leery of spending $200 for the try. That said, my bike came to me with a heated Corbin on it which I suspect is quite a bit taller than the OEM low narrow. Link to comment Share on other sites More sharing options...
srdjan Posted February 10, 2019 Share Posted February 10, 2019 I have bought Top Sellerie dual gel seat. It is very comfortable but it is more width and taller as well, less sporty movements on bike. I am going back to OEM for sure. Those are FAQs on my bike. And I am 187cm tall :)Sent from my EVA-L09 using Tapatalk Link to comment Share on other sites More sharing options...
gloryracing Posted February 11, 2019 Share Posted February 11, 2019 Low seat and run a 190/50 instead of the 55. I suspect that would get you over an inch. Link to comment Share on other sites More sharing options...
srdjan Posted February 11, 2019 Share Posted February 11, 2019 Don't 190/50, it will have negative influence as on almost every bikeSent from my EVA-L09 using Tapatalk Link to comment Share on other sites More sharing options...
