Member Contributer Airfiddler Posted November 24, 2018 Member Contributer Share Posted November 24, 2018 Recently been doing some regular maintenance. Switch was quite sticky. took it apart, cleaned lubed, put it back together. seems to be smooth and working fine. My question is there more than one ball bearing in the upper part of the switch? There is one behind the push to cancel position, but is there another one? The reason I ask is I found a small ball bearing on my driveway, and I can't figure out where it came from. I also had both the clutch and front brake levers off to clean and grease them, but I didn't notice any ball bearings when I took them off. The service manual is no help with this question as it doesn't show a parts breakdown. Link to comment Share on other sites More sharing options...
