EvanVFR750 Posted October 26, 2018 Share Posted October 26, 2018 I was reading the other PMR handle bar switch Topic and saw the goldwing switch box mentioned by JZH. I thought it looked very close to the shape of the 8th Gen and I started doing some research. The gasket and plate under the clutch reservoir lid have the same exact part numbers listed on BikeBandit, leading me to believe at the very least the two reservoirs have the same bolt dimensions. I found it online at JPCycles and other sites, but I took a chance and ordered it from my local Honda dealership. They did warn me about electronics being nonreturnable, but I was fairly confident it would work, and it arrived the next day. I got it for $60.33 out the door. Part number 52-705LMA. For the black clutch side switch box. Im stoked to say it worked out. Installation was easy: Remove the two bolts from the reservoir lid and leave the gasket and plate in place. Place the switch box on top. Place included weather gasket on top of the box. Place original lid on top. Then, bolt it down with the included longer bolts. It’s been on my bike for about 100 miles now. I haven't experienced any leaks or any problems at all. The switch box has plenty of clearance along the windshield and upper fairing, even with the .9 inch MotoPumps bar risers. The wires routed down the side of the switch box and I followed the clutch line to the side of the bike. I was able to tuck all the wires away under the tank. I swapped the middle rocker switch for a momentary switch. I was hoping to place it far right, but the switch I bought was too long and the metal for the bolt-through-hole blocked it. The momentary button was to build in a garage remote. 🙃 Instead of wiring the the switch box to the battery, I wired the positive end all the way back to the license plate light, so my garage wouldn’t open when bike is off. I used one switch to switch the relay for the Clearwater Darla lights (I’m in love with these lights). And I still have an open switch for whatever future accessory I may stumble upon. Kwan Link to comment Share on other sites More sharing options...
Ohlias Posted October 26, 2018 Share Posted October 26, 2018 Quite interesting! Thanks for posting. I am certain this will be of use for quite a few looking at options. Link to comment Share on other sites More sharing options...
Member Contributer mello dude Posted October 26, 2018 Member Contributer Share Posted October 26, 2018 Great idea.. Link to comment Share on other sites More sharing options...
Member Contributer fink Posted October 26, 2018 Member Contributer Share Posted October 26, 2018 13 hours ago, EvanVFR750 said: I was reading the other PMR handle bar switch Topic and saw the goldwing switch box mentioned by JZH. I thought it looked very close to the shape of the 8th Gen and I started doing some research. The gasket and plate under the clutch reservoir lid have the same exact part numbers listed on BikeBandit, leading me to believe at the very least the two reservoirs have the same bolt dimensions. I found it online at JPCycles and other sites, but I took a chance and ordered it from my local Honda dealership. They did warn me about electronics being nonreturnable, but I was fairly confident it would work, and it arrived the next day. I got it for $60.33 out the door. Part number 52-705LMA. For the black clutch side switch box. Im stoked to say it worked out. Installation was easy: Remove the two bolts from the reservoir lid and leave the gasket and plate in place. Place the switch box on top. Place included weather gasket on top of the box. Place original lid on top. Then, bolt it down with the included longer bolts. It’s been on my bike for about 100 miles now. I haven't experienced any leaks or any problems at all. The switch box has plenty of clearance along the windshield and upper fairing, even with the .9 inch MotoPumps bar risers. The wires routed down the side of the switch box and I followed the clutch line to the side of the bike. I was able to tuck all the wires away under the tank. I swapped the middle rocker switch for a momentary switch. I was hoping to place it far right, but the switch I bought was too long and the metal for the bolt-through-hole blocked it. The momentary button was to build in a garage remote. 🙃 Instead of wiring the the switch box to the battery, I wired the positive end all the way back to the license plate light, so my garage wouldn’t open when bike is off. I used one switch to switch the relay for the Clearwater Darla lights (I’m in love with these lights). And I still have an open switch for whatever future accessory I may stumble upon. Kwan Great find indeed. Well done. Link to comment Share on other sites More sharing options...
headshrink Posted November 2, 2018 Share Posted November 2, 2018 Wow, looks good. What lights are you using down on your fork? Link to comment Share on other sites More sharing options...
EvanVFR750 Posted November 4, 2018 Author Share Posted November 4, 2018 On 11/1/2018 at 5:16 PM, headshrink said: Wow, looks good. What lights are you using down on your fork? Theyre the Clearwater Darla lights with yellow lens covers. The universal kit was so incredibly easy to install. The wiring relay and everything was pre-made as a kit, it just needed to be routed around the bike. It came with a dimmer rheostat, mounted right in front of the clutch perch. Seen in picture 1. It came with several bolt lengths depending on which bolt you swap out to mount the lights. Plus they’re local to Sacramento. And made in USA 🇺🇸 Link to comment Share on other sites More sharing options...
Member Contributer VARIABLE9 Posted November 4, 2018 Member Contributer Share Posted November 4, 2018 Those lights are $500? They look pro, so I can see a high price. Just not sure if it should (maybe I should say “I’m not sure I personally would pay”) be $500 high. Link to comment Share on other sites More sharing options...
Katie Posted November 4, 2018 Share Posted November 4, 2018 Wow. Thought I might get one of these switch sets for my VFR (I need to replace the LED spotlights). Just checked the Amazon price and they are £65 + £30 shipping! 😲 Link to comment Share on other sites More sharing options...
EvanVFR750 Posted November 4, 2018 Author Share Posted November 4, 2018 3 hours ago, VARIABLE9 said: Those lights are $500? They look pro, so I can see a high price. Just not sure if it should (maybe I should say “I’m not sure I personally would pay”) be $500 high. Yeah it’s a high price but most kits are around that $300-400 price point anyways. And you still have to buy a mounting bracket, another $50-80. This kit bolted right in, easier for me. There are some cool features other kits don’t have: being dimmable and coming with the dimmer pre-wired. It’s triggerable meaning it can be wired to the horn to go full power when the horn is honked, or wired to the high beams to go full power on high beam/flash to pass. It was worth it to me to go with them since it’s local. If I have any problems with a bracket or a bolt I can just ride up to their shop. I met the owner while I was there, excellent customer service. Spent some time picking out bolt lengths and planning out potential mounting points for the dimmer rheostat. Its just one of the options among the various companies that make lights. Link to comment Share on other sites More sharing options...
EvanVFR750 Posted November 4, 2018 Author Share Posted November 4, 2018 24 minutes ago, Katie said: Wow. Thought I might get one of these switch sets for my VFR (I need to replace the LED spotlights). Just checked the Amazon price and they are £65 + £30 shipping! 😲 Yikes! Maybe your dealer can do a better price? Link to comment Share on other sites More sharing options...
Member Contributer VARIABLE9 Posted November 4, 2018 Member Contributer Share Posted November 4, 2018 Cool thanks for the info! Link to comment Share on other sites More sharing options...
headshrink Posted November 5, 2018 Share Posted November 5, 2018 On 11/4/2018 at 4:55 AM, EvanVFR750 said: Theyre the Clearwater Darla lights with yellow lens covers. The universal kit was so incredibly easy to install. The wiring relay and everything was pre-made as a kit, it just needed to be routed around the bike. It came with a dimmer rheostat, mounted right in front of the clutch perch. Seen in picture 1. It came with several bolt lengths depending on which bolt you swap out to mount the lights. Plus they’re local to Sacramento. And made in USA 🇺🇸 I thought they might be. Think Folsom PD is using them on their BMWs. although they could also be Denalis. I haven't installed it on my VFR yet, but I put cheapo versions on my other bikes. Works great, although I like the yellow look better than the amber filter I have. I have a "smart" dimmer that's wired to be triggered by my high-beam. Been meaning to transfer this stuff over to the Interceptor. Link to comment Share on other sites More sharing options...
