faran
2000 VFR SMC Re-build Question
Alright, so I had brake fluid seeping from SMC and it needed to be rebuild.
I have done the rebuild and no more leaks/seeping, but now when I push on rear brake, can hear a slight thumping sound and that disappears after 2nd or 3rd push on rear brake pedal. Is it normal?
Maybe just for me, but it was a real pain to install the circlip back into SMC bore, is there a special trick to install and push down on connecting rod, brake piston and circlip — all at the same time?
Can the noise be caused if snap ring(circlip) is not seated properly? Thank you for the help and advice.
Share this post
