Is my brake pedal bent?
RobF
I bought my 2005 used in 2014. It had suffered a couple driveway tip-overs and had the scratched bodywork to prove it. No big deal.
The other day, I was installing a set of BLS lowering blocks and the brake pedal alignment caught my untrained eyeball. I had always thought of the VFR's rear brake pedal placement as somewhat  "discreet" as in "tucked out of the way", but now I was wondering if my bike was something of a sad outlier and rather than having a "discreetly positioned" pedal, maybe the pedal was just "bent".
Here is a photo:
Is my brake pedal bent in toward the bike, or is the misalignment between the plane of the footpeg bracket and the tread lines of the pedal normal?
I would like to be able to answer with certainty but mine has been bent in towards the bike for so long, I don't remember what the positioning actually was.  But it does look to be bent inwards a bit
On 10/10/2018 at 4:23 AM, Marooncobra said:
Mine is the same but I have heated it with a torch and bent it out for a more 90 degree angle
Hey MaroonCobra, what was your technique for bending out the rear brake?
I have bent back several aluminum levers. I use a closed-end wrench, insert the lever into the wrench and carefully and slowly bend back toward where it belongs. I've never broken one in the prosess and have never had a bent one break on subsequent tip-overs. I imagine there is a too-far point but I've never gotten there. I did the work while the levers were on the bike as opposed to removing then bending. YMMV.
Sorry, only just seen your post. I removed the brake pedal from the bike and put the end that clamps onto the master cylinder in a vice. I then used a blow torch to heat up the pedal and used a Ring spanner. I just made sure I didn’t apply too much heat!!!
  • 2 months later...
I used MaxSwell’s open ended wrench rear brake pedal bending technique and am now squared off again. A small piece of the toepiece underside splintered off but a touch with a metal file or dremel sander should fix me up. Sorry for the delay but I had to wait until the weather warmed up a bit here in Maryland to avoid cold snapping the metal. Any suggestions on lowering it by an inch to match lowered footpegs?
Nice work straightening your pedal.
I did an off road experience day once and the guys running it used MaxSwell’s close ended spanner/wrench trick many times on the levers of downed MX bikes. Never saw a single one snap.
That’s built into the factory rear sets. Loosen the 10mm lock nut and spin up the bolt. It should lower or raise the pedal. I like mine just lower than flat.
Thanks UrbanEngineer. I spun the adjusting bolt down farther into the U-channel, readjusted the rear brake light switch, and uncurled about 3 coils of the stoplight spring. Of course I had to remove the foot peg bracket, rear brake master cylinder, and heat guard to get to it. And naturally, I had adjusted it all the opposite direction first and then refitted everything nice and snug. Second time was a charm however, and it feels a lot better now! Thanks to the Forum for good tips.
