Sign in to follow this
InterceptoRRC79
VFR 800 2014 **KEY CODE**
Hello guys,
I'm in big searching for the Key code...
Bike was stolen in Australia, I've buy him on Ebay,... Papers are  (we already discussed this...)
I have to find a Key Code, to make a new key... Cause, original key I don't have... I don't know how to find a first owner to please him,or something...
I opened the seat lock, I've found on him some numbers/simbols...
So if someone know if this symbols on next pictures can help something... It would be great...
Don't know too much about it so... Thanks for understanding
Share this post
I assume as it came from Australia it will have the HISS security system? If so you need to do more than just cut a new key. Do you have any key at all that starts the bike or the original HISS code? If not you will have to purchase a used ECU and the key associated with that ECU to get the bike to run. You can get these off eBay with all of the locks from crashed VFRs. I think there is someone on eBay that can cut a key and program the HISS key if you send them the ECU. Good luck.
Share this post
You need the key number.   Mine has 3 numbers.    A locksmith may be able to cut a key if you take him the lock tumbler.  New keys will need to be coded.
Contact Honda they may be able to help.
Share this post
Marooncobra
Thanks for helping,
I've found a guy (one member on this forum suggested me this guy), I can paste the link if someone needs..
I know that I have to make more than just key cutting...
But we can't open the Gas Tank, I don't have ignition cylinder to make a Copy, and I don't know where I can find a key code...
Share this post
Sir,
Please if you can check anyhow,  if the key code is hidden on rear seat lock cylinder?... I know I searching a lot,, but if you can anyhow help.... No another way to find out.. I don't know another way to get  informations
Thanks mate
Share this post
Tnx guys
I've already make problem done... Pretty cheap,
Guy from Poland 🇵🇱 programed two keys (without  Original one), and everything is fine
200€ cca with new ignition cylinder from some other Honda...
Share this post
On 9/12/2018 at 2:20 AM, InterceptoRRC79 said:
Sir,
Thanks mate
Locksmith can find that code easily you won't have to think about it a lot.
Share this post
