VFR80025th Posted July 5, 2018 Share Posted July 5, 2018 Hi guys, I have about 9000kms on my PR4s and they have performed great. I ride as aggressive as I can on my VFR and probably ride more straight than twistys due to where I live in Toronto. So since i'm getting some flattening of the rear tire I get spooked when leaned over due to the transition from the flatter part of tire to the extreme sidewall. You guys get the same feeling. Bike kind of dips down once over the flatter area of the tire and it spook me out at times, more so at slower speeds when leaned than high speed sweeping corners at 120kmh and over. Anybody want to chime in. Thxs and Ride Safe! Link to comment Share on other sites More sharing options...
Member Contributer Duc2V4 Posted July 5, 2018 Member Contributer Share Posted July 5, 2018 With squared off tires, that is what one should expect. Even if I have plenty of tread left on the side, usually it isn't too bad, as I try and get in a some twisty miles if/when I can, I will change out the tire for fresh rubber. Although this means I did not get a full life from the tire, I feel better about having new and more rounded rubber. Link to comment Share on other sites More sharing options...
Sweeper Posted July 5, 2018 Share Posted July 5, 2018 Trade tires with one of the guys from the mountains. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Member Contributer Egg on Leggs Posted July 5, 2018 Member Contributer Share Posted July 5, 2018 Link to comment Share on other sites More sharing options...
Member Contributer YoshiHNS Posted July 5, 2018 Member Contributer Share Posted July 5, 2018 Did mostly commuting on my old VFR. Took it to some real twisties with the tires for the first time. Front was sorta cupped and rear had a flat spot. Definitely could feel the bike get all upset rolling over that part of the tire. In the garbage they went and fresh stuff on. Not worth having that on your mind while you are riding. Link to comment Share on other sites More sharing options...
