Stigger Posted July 4, 2018 Share Posted July 4, 2018 Has anyone fitted these lowering blocks? https://www.ebay.com.au/itm/Honda-VFR800-All-Models-Rider-25mm-Footpeg-Lowering-Kit-UK-Supplier-Warranty/263109022915?hash=item3d428514c3:g:QSsAAOSwFqJWnsaM I've fitted them an they work fine, but the original spring no longer works. The problem is that whilst the surfaces the spring pressed again were in the same plane originally they are at 90 degrees to each other once the blocks are fitted. Any ideas, help, solutions? Link to comment Share on other sites More sharing options...
