Member Contributer Skids Posted June 26, 2018 Member Contributer Share Posted June 26, 2018 A member on a Crosssrunner forum (same engine as the 8th Gen VFR800F) has reported strange misfiring on his bike. Even after being looked at by a Honda mechanic, the issue was not solved. He finally decided to check the Quickshifter, fitted new by the dealer 10 months previously to find there was water ingress at both the rubber gaiter on the shift arm plunger allowing water into the unit itself and the protective sleeving around the cables that connect the multiplug at the other end is open to water ingress too. Removing the Quickshifter has sorted the issue. Just a head's up for anyone who has a misfire that you can't find a reason for. Link to comment Share on other sites More sharing options...
