Member Contributer mkrouse Posted May 19, 2018 Member Contributer Share Posted May 19, 2018 I've purchased a OEM replacement sensor. Applied some gentle prying force to remove the old, worn sensor. Not budging. How much pressure does it take to slide that thing off the shaft? Link to comment Share on other sites More sharing options...
Member Contributer Terry Posted May 19, 2018 Member Contributer Share Posted May 19, 2018 Should only be held in place by friction of the plastic on the steel shaft. Link to comment Share on other sites More sharing options...
M1962 Posted June 3, 2018 Share Posted June 3, 2018 Which bit isn't coming off? The cable with the sensor on the end has the nylon wheel and that just fits onto a shaft if I remember rightly. I don't remember anything being stuck. Or are you just replacing the nylon wheel? Link to comment Share on other sites More sharing options...
Member Contributer mkrouse Posted June 3, 2018 Author Member Contributer Share Posted June 3, 2018 Nylon wheel. I finally used a snap ring pliers. Worked my way around and it came off. New one was no treat to attach as it didn't slide on easily. Today I'm replacing a shower pipe with vice grips. My life is exciting, no? Link to comment Share on other sites More sharing options...
