Urbanengineer
Sanding down VTEC Lifters? $34 a Bucket? What!?
Hello All.
I'm in a predicament. I am doing the V4 valve adjustment myself (I don't want to hear about how you didn't have to do it for 100k miles 😀) and I need a LOT of shims unfortunately. I actually likely need to replace 5 VTEC LIFTERS ALONE! And those cost $33.95 on bikebandit.
Can I shave down the top of the lifters using a band saw or something similar? Costs are adding up on this VFR and I didn't anticipate $160 worth of bespoke valve shims/lifters!
If not (probably not), does anyone have any VTEC lifters sized 2.50mm to 2.75mm for sale? I need 5!
Share this post
Something doesn't add up here.
I paid around AU$70 for a Hot cams shim kit, with lots of shims (over 120 from memory).
Don't touch the buckets, they are case hardened and can't be cut, only surface ground, but I don't see a need for that.
Why do you need new lifters?
You don't need that many shims, are you sure you know what you're doing?
Share this post
This is a 6th gen. It has 8 regular shims, and 8 VTEC "lifter" buckets with set shim heights printed into the bucket.
See here: https://www.ebay.com/itm/Honda-VFR-800-Vtec-Shim-Bucket-Valve-Adjustment-286/282090986394?hash=item41adeedb9a:g:g0IAAOSwzJ5Xe~5c
8/16 of my valves are out of clearance, I know how measure... This is a sixth gen so it requires removing of the camshafts and modification of the VTEC buckets to even check clearance. I swapped lifters side to side (with the same measurement) into different slots to make sure it wasn't an issue with the VTEC bypass I did and the numbers are the same.
I should clarify green means in clearance, yellow means bottom clearance, and orange means OUT of clearance. The red numbers indicated a VTEC valve.
So still waiting on verification from someone that knows VTEC ones, but am I stuck having to spend $33 a valve lifter?
Share this post
damn that sucks, I would say no they cannot be modified, if you did I think they would wear very fast and damage a cam. I do not have any laying around.
Share this post
I asked on VFR people and people are too busy riding to answer if they have any lol. I learned I can repurpose 3, so I only have to buy 4... great... $135 for 4 lifters. RIP!
Share this post
Maybe have them machined at a local shop? Or using a lapping tool?  I have sanded normal shims down myself and measured with a micrometer to get my old 5th gen shims in spec. Just taped a wet sandpaper to a piece of glass and sanded it in a figure 8 till it was down to the correct thickness. But these buckets are a pain in the ass.  Not many vtech owners seem to mess with valves I have found. Put it in a vise and get a sanding disk small enough to fit on a drill and sand away? Might not be flush than? Just brain storming, I dont want to think you want to deal with the outside of the bucket you might sand it too thin and it will break but the thickest part of the underside?
Share this post
I would go with the Wet and Dry on a glass plate and lap the top of the bucket down until you get the correct thickness.
Check your initial measurements again and did you use the "locking" pins to lock the VTec buckets to the followers.
Part number:  07XMZ-MCEA100
Without the locking pins the VTec valves are always going to be tight.
Check the factory manual for the 6th Gen
Share this post
Create an account
Register a new account
Sign in
Sign In Now
