jeange Posted May 8, 2018 Share Posted May 8, 2018 Does anyone know if the bolt in the red square below is honda part #90106-MCW-D00? Sent from my SM-G960W using Tapatalk Link to comment Share on other sites More sharing options...
Nightlight Posted May 9, 2018 Share Posted May 9, 2018 Looks like 90683-GAZ-003https://www.bikebandit.com/oem-parts/2009-honda-interceptor-800-abs-vfr800a/o/m150903#sch612334Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Member Contributer Lorne Posted May 9, 2018 Member Contributer Share Posted May 9, 2018 I think you'll find that this is the part you seek: 16: SCREW, PAN (5X20) 90103-MBG-000 "(5X20),AC 2AC" Fyi, p/n 90106-MCW-D00 is a larger fastener with a collar p/n 90683-GAZ-003 is the ubiquitous plastic clip that Honda use for many bodywork panels Link to comment Share on other sites More sharing options...
jeange Posted May 11, 2018 Author Share Posted May 11, 2018 On 5/8/2018 at 11:20 PM, Lorne said: I think you'll find that this is the part you seek: 16: SCREW, PAN (5X20) 90103-MBG-000 "(5X20),AC 2AC" Fyi, p/n 90106-MCW-D00 is a larger fastener with a collar p/n 90683-GAZ-003 is the ubiquitous plastic clip that Honda use for many bodywork panels I think it's that one as well. How did you find that? I look on the parts fiche for the upper and lower cowl and the part number is listed but I wasn't able to find it on the image. Lower cowl: https://www.partsfish.com/oemparts/a/hon/5053f5c6f870021c54be7cc6/lower-cowl Upper cowl: https://www.partsfish.com/oemparts/a/hon/5053f5c6f870021c54be7cc5/upper-cowl From the parts fiche it almost looks like #10 on the lower cowl but it's not the right part #, it's the one with the collar: Link to comment Share on other sites More sharing options...
Member Contributer MaxSwell Posted May 11, 2018 Member Contributer Share Posted May 11, 2018 3 hours ago, jeange said: I think it's that one as well. How did you find that? I look on the parts fiche for the upper and lower cowl and the part number is listed but I wasn't able to find it on the image. Lower cowl: https://www.partsfish.com/oemparts/a/hon/5053f5c6f870021c54be7cc6/lower-cowl Upper cowl: https://www.partsfish.com/oemparts/a/hon/5053f5c6f870021c54be7cc5/upper-cowl From the parts fiche it almost looks like #10 on the lower cowl but it's not the right part #, it's the one with the collar: What is "the one with the collar" you are referring to? Link to comment Share on other sites More sharing options...
Member Contributer Lorne Posted May 12, 2018 Member Contributer Share Posted May 12, 2018 Jeange: The PartsFish link from Nightshade has a different numbering scheme. I circled the part you want, as indicated in your original post, in red. It is p/n 16 in the upper cowl drawing and p/n 16 in the lower cowl drawing. Theses fasteners are threaded all the way, and fit flush to the fairing surface. Jeanne + MaxSwell: The collared fastener are circled in blue in the lower cowl drawing. They fit into the recesses in the fairing and have no threads near the head. Link to comment Share on other sites More sharing options...
Member Contributer MaxSwell Posted May 14, 2018 Member Contributer Share Posted May 14, 2018 That's what I thought. Thanks for the explanation. Link to comment Share on other sites More sharing options...
