v4hrc Posted May 7, 2018 Share Posted May 7, 2018 Hey y'all. I'm in the Knoxville area and had a mishap today on my 5th gen. I'm ok, bike is mostly ok other than the left side radiator. Does anyone in the area have a spare? I see the 6th gen is a different part number but is it a close enough fit that it would work? Link to comment Share on other sites More sharing options...
Member Contributer VFROZ Posted May 7, 2018 Member Contributer Share Posted May 7, 2018 You can fit a right side 6G with minor modifications. The left side is a lot harder as the mounting points are different. Link to comment Share on other sites More sharing options...
Member Contributer Cogswell Posted May 7, 2018 Member Contributer Share Posted May 7, 2018 IIRC the the 6th gen's has 2 fewer rows, so should have a bit more room - though that may create some issues with sealing against the fairing to get all the air through the rad. Link to comment Share on other sites More sharing options...
Member Contributer VFROZ Posted May 7, 2018 Member Contributer Share Posted May 7, 2018 3 hours ago, Cogswell said: IIRC the the 6th gen's has 2 fewer rows, so should have a bit more room - though that may create some issues with sealing against the fairing to get all the air through the rad. Back to front, the 6G has two more rows than the 5G as well as having different mounting points on the left rad. Link to comment Share on other sites More sharing options...
