Member Contributer Captain 80s Posted April 7, 2018 Member Contributer Share Posted April 7, 2018 So I never use added air pressure in the front suspension and I like to be able to slide the forks where I want. You can't do that on the VF700/750/1000 because of the stupid "FR FORK EQUALIZER" So let's eliminate it. Step 1 should be remove the forks I suppose. OK. I considered a few options on how to accomplish this. First thought was to have them welded shut. Well that means complete disassembly to remove all contamination. Nah. Solder would work too, but I probably should disassemble to clean too. I experimented on a VF750F fork tube and it worked good, but I wasn't completely confident even though the area will probably be captured by the upper triple clamp. And also I didn't want to disassemble to ensure a proper job. I decided on this route. Let's drill and tap for some set screws. I hung the forks upside down as the fork oil drained to perform the work so any debris could flow out. After drilling, tapping and deburring I flushed them out real good with some WD40 and contact cleaner and then let them continue to drain through the night. I filed the stainless set screws down to a reasonable thickness so they wouldn't interfere with any preload spacers. We'll install them with a little thread lock. Installed and dressed down for any high spots. Now I can put the forks wherever I want. I've decided to start with the back up ring that used to be below the crossover moved up to the triple clamp, 19mm. I have proper front springs in the forks and it was already riding higher than stock, so this is not extreme. All my big VFs will be getting this mod except for my mostly stock 86 VF1000R. These forks will eventually be going on a VF750F as I am currently going through another set of 1000F forks that are getting new seals, bushings, springs and cartridge emulators. That way I can just swap the forks with minimal down time. I didn't have to do this right now, but it will be a little while before I can afford to finish the other forks and this only took one evening and a some time this morning. Link to comment Share on other sites More sharing options...
Member Contributer Captain 80s Posted April 7, 2018 Author Member Contributer Share Posted April 7, 2018 Front end is definitely a little lower, I had to put a board under the front tire to get the jack out. Oh yeah, and a new seat cover on a NOS seat pan and foam. Looking tasty, can't wait for the rain to stop. "I couldn't afford NOT to buy it!" Link to comment Share on other sites More sharing options...
squirrelman Posted April 8, 2018 Share Posted April 8, 2018 how did you get a drill into the curved surface ???? Link to comment Share on other sites More sharing options...
Member Contributer Captain 80s Posted April 8, 2018 Author Member Contributer Share Posted April 8, 2018 20 minutes ago, squirrelman said: how did you get a drill into the curved surface ???? There's already a hole Squirrel. That's the whole point. Link to comment Share on other sites More sharing options...
squirrelman Posted April 9, 2018 Share Posted April 9, 2018 23 hours ago, Captain 80s said: There's already a hole Squirrel. That's the whole point. Link to comment Share on other sites More sharing options...
