Anthony Posted March 14, 2018 Share Posted March 14, 2018 Hi all.anybody else have a creaking clutch lever ? Tried lubing the pivot sounds like it coming from the master cylinder Link to comment Share on other sites More sharing options...
Member Contributer Grum Posted March 15, 2018 Member Contributer Share Posted March 15, 2018 11 hours ago, Anthony said: Hi all.anybody else have a creaking clutch lever ? Tried lubing the pivot sounds like it coming from the master cylinder Hi Anthony Undo the pivot lock nut, now back off the pivot screw, it shouldn't be screwed in firmly, just to the point where it tightens then back it off a little, as this clamps down on the clutch handle surfaces causing the creaking, the lock nut can then be tightned making sure you have a screwdriver held in the pin so it doesn't move as you tighten the lock nut. Make sure its all well lubricated. I've had the same issue. Let's know how you get on. Cheers. Link to comment Share on other sites More sharing options...
Anthony Posted March 15, 2018 Author Share Posted March 15, 2018 Cheers will try it at the weekend Link to comment Share on other sites More sharing options...
