VFRUNNER
WHAT DID YOU DO TODAY TO YOUR VFR 6TH GEN ?
Working on the headlights. This has been longggg overdue. I've been spending a lot of time with the R6, haha. VFR is now getting some love again.
Share this post
Nic3 job  looks great   . Send picture when it's done .  Here's a picture of what soon will be the look of your bike
Share this post
Replaced the front cam tensioner and opened up the 0.5mm hole in the new gasket to 2.5mm hoping this keeps things quiet.
Share this post
Have to share, Runners note on the source for the oem hugger was aces.  The best price and shipped extremely quick for the default price.  Just from looking at the hugger, it will last the life of the bike.  My aftermarket did not, so recommending for others.  Thanks to Runner for being the pioneer and source for this.
Dave
Share this post
Dave
Thanks  Dave  glad to help you out  and others
Share this post
Here is a sneak peek of my bike with the tail swap of a 2014 cbr1000rr tail on my 6th gen . I'm just about done .
Share this post
Dave
Clutch cover is complete .  Just waiting on pro bolt to come through the shipping to Canada from UK seems to be taking long . Can't put the cover on until I get the new bolts .  .  But here is the the complete cover off the bike with light on .
Share this post
Is that SEBs clutch cover with a light or is that something you added?  It looks nice....:beer:
Share this post
It is certainly, sebs fabulous  workmanship.   The light I added. My personal touch
Share this post
Just replaced my rear shock with an Ohlins STX46 HO 043 on 50k mls 2005 abs model.
Bugger of a job trying to get the remote adjuster out. But its in now got a few bits still to go on due to failing light and the odd spring shower!!
I have set of F4I Fork internals on their way from ebay, cant make my mind up whether to respring and put emulators in before fitting. I do road/commute so looking for a ride erring on plushness.
Share this post
Nice. I'm sure it going to make a great difference . Where did u get the shock ?  Good price?
Share this post
Got it through ebay UK from an italian company Genial Motor in Rimini, Check out their site.
Share this post
Got some OEM short velocity stacks ($30au for 2) and replaced the long ones... for s&gs
And took the piece of foam out that is at the front of airbox....I thought I'd already done that.
Seems to have smoothed out slow speed low % throttle and also deeper intake noise
Share this post
What set up did you use for the lights?  I just received one of Seb's custom clutch covers and the lighting looks REALLY cool.
Share this post
Hey, I used a waterproof led strip . And cut it to the size I needed it, witch was 8 inches.    The led has double sided tape on the back I then stuck it to the cover . I purchased some heat and chemical resistant epoxy and cover the whole light to protect it even further.   The reason I mounted the way I did was because it gave they best lighting . I tried different positions but the one I have pictured worked best. .   I was going to go with single led but when I laid it out it was to messy.
Hope this helps .
Share this post
The light is also nice bc It allows you to see the oil level at night .
Share this post
Just the usual on mine.  Removed snorkel.  PAIR valve delete.  Flapper delete.  Removed rear fender, raised license plate higher.  Blacked out the OEM windscreen.  Added tank knee pads and belt guard.  Sargent seat.  Rear luggage rack.  Plasti-dipped the wheels (anthracite).  Staintunes.  Cortech tank bag.  Might add a Power Commander, but it's running so well I might leave it as is.  Nothing over the top, just enough to make it my own.
Share this post
Took my forks off and apart. Putting new seals,  bushings and oil. Bush mechanic style of keeping the bike upright while front wheel is off.
Share this post
Now's the time to throw in some internals from Daugherty Motorsports!
Share this post
I whipped out a set of exhaust guards for my soft bags. Something easily put on and taken off. Still need to paint them.... or make another set where the welds aren't so embarrassing!
Started with flat stock and some small tubing. Using map gas, hammer, vice, cutting wheel and a sharpie, I was surprised on how well they came out for the first try. First bent the tabs that go on the Givi mounting bolt towards the front. Then bent the tubing to follow the lines of the exhaust. Bent the upper/rear tab to "lock" into the Givi mount, keeping the entire piece from rocking inward. the one forward nut is all that is needed to remove/replace to take the guard on and off.
Share this post
Tried out the new homemade exhaust guards for the soft bags. They work well. Looks like I didn't take any pics after painting them black, but they look pretty sanitary in black. Here they are with the bags on. You can kinda see them, the left one anyway.
Share this post
Hope this helps .
Hi Vfrunner.
Thats a fantastic Seb clutch cover. But, man, I would be very concerned about your internal lighting, if that stuff gives way inside your engine, who knows what damage it will cause.
Share this post
