autopilotone
Complete brake failure on a VFR800 5Gen
Check out this guy's experience of complete brake failure on a VFR800 5Gen.
Below is an abstract for the brake failure and a good reminder for us all.
"The simple reason for the brake failure was that the hydraulic fluid had boiled resulting in zero pressure to force pads against discs. Contaminated brake fluid (I’ve not changed the fluid during my period of ownership, nor do I know if it’s ever been done during its ten years in action) was the simple reason behind the artery-flushing experience. Because it had absorbed so much water, the fluid was unable to deal with the massive heat the repeated braking had generated."
https://ciamotorcycleblog.wordpress.com/tag/vfr800/
Share this post
Scary story but definitely avoidable given the nature of his actions over the course of the day.
Lets hope that advertised dealer did a thorough flush before he added that DOT 5 :comp13:
Share this post
I wonder if he neglects his oil and tires too. Or for that matter, when did he last flush his clutch fluid?
Share this post
And they put DOT 5 (FIVE!!!!!!!!) in?????
Did he take it to a HD dealer??? :unsure:
4 yes
5.1 yes
5 no!!!
Share this post
I'm going to assume that he doesn't really know what brake fluid grade they put in or what the difference between them is for that matter. It doesn't seem that this is a person who is mechanically inclined.
Share this post
How hard is it to change fluid duh! its a given to change all fluids when you purchase a bike or at least an inspection.
Share this post
Speechless !
Share this post
3 minutes ago, Woodie said:
Speechless !
Ditto
Share this post
He did change the oil in 2011 apparently:
" However as it’s been such a long time such I got my hands dirty, doing the work caused quite a bit of physical strain, not to mention a slightly fuller swearbox!  I’d forgotten just how flexible you need to be to wield a spanner with any sort of skill. Access to fairing fasteners and drain plugs requires gymnastic-levels of contortion which my older framework struggles to achieve these days, especially without a work bench."
no mention since then
Share this post
DOT 4, DOT 5, DOT 6... whatever it takes.
It's one thing to skip maintenance, that's not smart of course but it takes a lot more commitment to ignore the brake fade that comes before losing your brakes entirely.  Boiling fluid probably caused drag also which should have been noticeable.
Share this post
Not to nitpick, but mixing DOT 4, DOT 5, DOT 6 could be a real issue. DOT 5 is silicon based brake fluid and will not mix
with any of the other fluids. It will clump and possibly cause issues. That's why it was mentioned about DOT 5 earlier.
Share this post
Sponsored by an insurance company....... dumbass!
Share this post
Funny enough. Harley recalling a TON of bikes for brake fluid.
https://www.asphaltandrubber.com/recall/harley-davidson-brake-bleeding-recall/
I think part of it is that they use two different grades of brake fluid for the clutch and brake, or the front is different than the rear, and that perhaps even some dealerships may have mixed them up. If that's true, then you will have some serious consequences. But it's pretty stupid from the start to require two different grades of fluid that aren't compatible on the same bike.
Share this post
