Straycat Posted July 12, 2017 Share Posted July 12, 2017 Hi Guys, is a rear comstar from a VF1000R a straight swap on the 85 Interceptor 500f ? I have a set of NS400 Comstars and the front wheel may work off that, but id like a matching rear wheel. thanks Link to comment Share on other sites More sharing options...
Member Contributer Captain 80s Posted July 12, 2017 Member Contributer Share Posted July 12, 2017 Not a bolt on. More than likely it will require some machining to the hub to get the chain lined up AND the wheel lined up with the front. A caliper bracket to match the diameter of the 1000R rear disc and then some custom spacers to make up everything else that has now changed. Knowing that CBR-F2 wheels are possible on a 500, the Comstar should be as well. Link to comment Share on other sites More sharing options...
Straycat Posted July 12, 2017 Author Share Posted July 12, 2017 OK, thanks for the reply ! Link to comment Share on other sites More sharing options...
