Member Contributer CHUCK2 Posted November 26, 2016 Member Contributer Share Posted November 26, 2016 The 2Bros. Slip-On on my '98 rattles inside. I'm figuring it needs to be repacked which I have no experience doing. I want to stop it from rattling without changing the loudness of it. Is that possible? Link to comment Share on other sites More sharing options...
Member Contributer MBrane Posted November 26, 2016 Member Contributer Share Posted November 26, 2016 2 Bros sells repack kits. It not too difficult if you are reasonably mechanically inclined. The only thing you'll really need other than the kit is a decent rivet gun, a drill and some black hi-temp silicone. Link to comment Share on other sites More sharing options...
Member Contributer CHUCK2 Posted November 27, 2016 Author Member Contributer Share Posted November 27, 2016 Thanks MBrane I'm concerned it'll end up being too quiet. What would the silicone be used for? Link to comment Share on other sites More sharing options...
Member Contributer MBrane Posted November 27, 2016 Member Contributer Share Posted November 27, 2016 I don't think I've ever heard a 2 Bros pipe that was too quiet. The silicone is used to seal around the rivets, and end caps. Link to comment Share on other sites More sharing options...
Member Contributer JZH Posted November 27, 2016 Member Contributer Share Posted November 27, 2016 If it's an old design, like the C2 oval, the fiberglass matt is wrapped around a perforated steel tube "core", which is retained in place by the cast alloy end caps. The core can rust and loosen over time (it wasn't stainless on mine), which could rattle. I have the "quiet tip baffle" in mine, which can rattle a but when everything else gets loose. Drill the rivets out and see... If you re-pack it, it will change the sound. Odds are that the packing is so old now that it is hardly doing any muffling! Ciao, Link to comment Share on other sites More sharing options...
Member Contributer CHUCK2 Posted November 27, 2016 Author Member Contributer Share Posted November 27, 2016 Thanks JZH I'm quite certain that it is a C2. I've never done anything with rivets before so it ought to be interesting. Will the holes end up bigger after drilling the rivets out? Link to comment Share on other sites More sharing options...
Member Contributer JZH Posted November 27, 2016 Member Contributer Share Posted November 27, 2016 TBR used stainless steel pop rivets, which can be a bugger to drill out, but if you choose the right size drill bit you shouldn't have to enlarge the holes. You can get new rivets at McMaster-Carr, I believe. Ciao, Link to comment Share on other sites More sharing options...
Member Contributer CHUCK2 Posted November 27, 2016 Author Member Contributer Share Posted November 27, 2016 Are the rivets likely to be different then what I can get locally? Link to comment Share on other sites More sharing options...
Member Contributer MBrane Posted November 27, 2016 Member Contributer Share Posted November 27, 2016 The repack kit comes with the correct rivets. They are 1/8" large flange if you want to get some locally for spares. Link to comment Share on other sites More sharing options...
Member Contributer JZH Posted November 27, 2016 Member Contributer Share Posted November 27, 2016 I actually replaced all of the rivets in mine with M4 stainless buttonhead screws, but before I decided to do that I think I had encountered some difficulty finding stainless steel large flange rivets locally. YMMV. Link to comment Share on other sites More sharing options...
Member Contributer CHUCK2 Posted November 28, 2016 Author Member Contributer Share Posted November 28, 2016 Thanks JZH. I also would like to use screws. Did they stay tight? Link to comment Share on other sites More sharing options...
